4x4van
Sep 15, 2016Explorer III
BOTH pieces must be located and oriented where there is good support; not always easy, but pretty much required. If the location of one results in a bad location for the other, then the first needs to be relocated or modified.
If relocation is not possible, then how about a larger aluminum plate (1/8" thick, painted) attached (using screws or pop rivets) to either the wall or the door to give additional support where is needed?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
