NewToUs's avatar
NewToUs
Bathroom Toilet Paper holder mounted Sideways with pictures
Our trailer is almost 10 years old, we are the 3rd owners and yesterday it got a plastic toilet paper holder ! We mounted it sideways with 2 little screws. There is a narrow wall between the shower and the bathroom door. Now when you sit on the toilet, the toilet paper is right in front of you to the right. It took 5 minutes to install and its so practical.
Highly recommend this Mod !
Click For Full-Size Image.
  • Dennis12 wrote:
    How do you know that the roll is installed properly to achieve the proper wiping procedure. Should we use the other hand during the procedure ?
    This is obviously an off-handed remark. Nice work.
  • How do you know that the roll is installed properly to achieve the proper wiping procedure. Should we use the other hand during the procedure ?
  • Our shower curtain has small pieces of velcro every 6" or so, attached to the wall, to avoid spilling water on the floor. I cant believe we did not do this mod earlier, its such a schlep to deal with the roll of toilet paper all the time. We often use our bathroom while on the road. Its shows you that all little nooks and crannies can be very useful in an RV.
  • I hope the shower curtain does its' job. Otherwise it is "soggy butt" time.:B Good mod! :)
    Barney
  • All you have done is to make the argument of which way the toilet paper hangs - in front of the roll, or in back, much more complicated! You have now added right or left! :P
  • DrewE's avatar
    DrewE
    Explorer III
    A very useful mod indeed.
    Lehman's sells a simple vertical toilet paper holder that would work well in a situation like this and would make changing the roll a little bit easier (not that it's really a hard job in any case).
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
