- bobndotExplorer III
D.E.Bishop wrote:
bobndot wrote:
If you alter or install seatbelts yourself make sure you anchor them to the vehicles frame.
Where does that come from? Don't most chassis say not to drill or weld on the frame.
I always remember reading chassis or framework. I would not weld to the chassis.
You could bolt through the floor using a metal backing plate. It would useless to bolt to wood that is part of a dinette or other weak structure, that was my point. I would make it as secure as possible. - ron_dittmerExplorer III
hobbssb wrote:
Hi hobbssb,
We're looking for a small (under 25 ft) so-called B+ that has 4 seatbelts, none of which face sideways. Preferably not a corner bed. Any suggestions? Thanks!
Your request implies accommodations for 4 people. Every B+ sacrifices the extra double bed over the cab. Though many B+ floor plans offer sleeping for 4 on the main floor, it is very disruptive to have 2 of the 4 sleeping in the living area.
FWIW: Our rear corner double bed rig SEEN HERE is 23'-8" end-to-end with seat belted seats facing forward officially for 5, but realistically for 4. Our 3rd captain seat spins abound to any orientation including forward. The dinette has a forward facing bench seat with seat belts for 2. Our 12 year old rig is still made today. CLICK HERE to get to the manufacture's website. - D_E_BishopExplorer
Where does that come from? Don't most chassis say not to drill or weld on the frame. - F1bNormExplorerOur ‘06 Winn Aspect 23b, a B+, has 6 lap belts in addition to the driver and passenger cab seats. 2 facing forward and 2 facing rear at the dinette and 2 on the side couch. Does not have anchor clips for current child seats. See: http://library.rvusa.com/brochure/06Aspectbro.pdf
Norm - claywayExplorerI still have a Bornfree rear door with the side couch, it is a 2009 model, at the time I had younger kids, I went to a shop that provides race car gear & worked with them on making a 3 point harness that worked on our couch
Just an idea that worked for us - garmpExplorer IIOur Phoenix Cruiser 2100, 22' long, had seat belts at the dinette, one on each side (no shoulder harnesses) and then the two in front.
- BillHoughtonExplorer II
SidecarFlip wrote:
Buy what you want and install the seat belts yourself. You can buy belts and harnesses online.
Well, but...
On our 2007 Itasca Navion, the rear bench for the dining table is on top of the heater, which takes up pretty much all of the space under that bench. It would be hard to impossible to install seatbelts on that bench. The front bench (facing backwards) has storage underneath, and two seatbelts.
Also, I'm not sure (haven't had occasion to look) that I could get to the underside of the floor to install seatbelts properly, even where I otherwise could.
So, if you find an RV that otherwise satisfies your needs, make sure that you can, in fact, install seatbelts everywhere you want them. - wildtoadExplorer IITake a look at the Winnebago Fuse 23T. Should be able to add a second set of belts on the dinette. Not sure if it would handle four adults but should work for two kids.
- JaxDadExplorer III
That's going to be a tough one, typically the replacement for the corner bed in a small unit is the cab-over queen, but a B+ doesn't have a cab-over bed.
In some of the Euro models (MB Sprinter or Ford Transit) there is a drop-down bed. In those cases though you might have another issue, unless you have the rear sofa that drops down into a bed, you really only have sleeping for 2 people. - bobndotExplorer IIIIf you alter or install seatbelts yourself make sure you anchor them to the vehicles frame.
38,780 PostsLatest Activity: Aug 05, 2026
