BillHoughton
Mar 18, 2019Explorer II
SidecarFlip wrote:
Buy what you want and install the seat belts yourself. You can buy belts and harnesses online.
Well, but...
On our 2007 Itasca Navion, the rear bench for the dining table is on top of the heater, which takes up pretty much all of the space under that bench. It would be hard to impossible to install seatbelts on that bench. The front bench (facing backwards) has storage underneath, and two seatbelts.
Also, I'm not sure (haven't had occasion to look) that I could get to the underside of the floor to install seatbelts properly, even where I otherwise could.
So, if you find an RV that otherwise satisfies your needs, make sure that you can, in fact, install seatbelts everywhere you want them.
38,782 PostsLatest Activity: Sep 02, 2026
