Usmcsousa's avatar
Usmcsousa
My Affordable LED conversion.
Hello all, Wanted to share my Latest Project in hopes that Others like me (Electrical Illiterate)will see just how easy this was.
First I ordered These from Amazon for $8.00 and free shipping.
One they came in I got to work. They can be Cut every Three Leds, So for My Use I could Fit 4 rows of 6 leds into my overhead light fixture.
I Cut them into 6 led strips
I then Cut some Scrap Cardboard to size, Removed the Adhesive backing tape, and layed them in this Order. (+ touching +, and - touching -)
Now it was just a Matter of connecting the Leads together.
I Scraped off the Plastic Top Covers a Bit to Expose a little More Connector to insure a good Solder Connection for the Adjacent connections
Then Soldered
and Soldered again
Repeated this Process until all 4 strips were connected
My Final Product
The picture Doesn't show just how bright these are, Probably about 50% brighter than the Non-led bulb it replaced.
Now its just a matter of connecting the wires to my current light fixtures, putting the lens covers back on, and on to the next project.
Please Be kind to me about my Soldering skills, the Last time I did anything like this was grade school.
I sure Saved a Boat load of money with this Project,
that $8.00 gave me 12 "light bulbs" . throw in about $0.40 worth of solder and $1.00 worth of 18 gauge solid wire. and if I didnt Already have a soldering iron maybe another $10.00
  • The four legged buddy laying on the seat would like the LEDs turned down a little bit. Trying to get in the snooze cycle!
  • Ron Nielson wrote:
    Great idea and execution. Shows what a little knowledge can do for you. I'm going to try this. Gotta be fun if nothing else.
    was definitely a fun little project. Has peaked my interest for other applications around my house with these LED tapes. I think next Ill add some working Headlights to my Sons Power wheels truck.
  • bdpreece wrote:
    I liked the idea of laying them side by side and dragging the solder across but,if you have not done so I would remove the cardboard as a possible source of fire. I don't know how hot these things get but not sure I would lay them on paper.
    thank you for your concern, I stupidly hadn't thought of that. I left one that i made on for 16 hours yesterday to see just how hot they get on the cardboard. they were warm to touch but nowhere near hot. For my application I think the cardboard will work just fine for the minimal usage hours they would be running.
    I would however use a circuit board or other flame resistant backing material for any future lighting project.
    thank you
  • Here's my application of that LED tape.
    The dinette area had the harsh light from the incandescent bulbs, but now it is softer.
    I also added a dimmer, so we can adjust the mood just as we like it.
    I really like your idea for replacing the incandescent bulbs. The tape is cheap and easy to work with. I might have to order some more to put in the light fixtures.
  • Great idea and execution. Shows what a little knowledge can do for you. I'm going to try this. Gotta be fun if nothing else.
  • I liked the idea of laying them side by side and dragging the solder across but,if you have not done so I would remove the cardboard as a possible source of fire. I don't know how hot these things get but not sure I would lay them on paper.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,404 PostsLatest Activity: Apr 14, 2026
