4x4van
Sep 05, 2013Explorer III
Big Katuna wrote:
So to help me understand, please clarify;
You use a 48-5050 in the ceiling lights with one or two snap off cove with one switch? How do you secure the flat panel? Does it just ride on the cover?
The single-bulb fixtures each got a single 48-5050 panel, the double-bulb fixtures each got 2 48-5050 panels (the double-bulb fixtures have a 3-position switch; off - 1 bulb on - both bulbs on). The 3M tape on the back of the panels would not work on my fixtures because of the concave inner surface, so I removed the 3M tape and just used a dab of silicone on two opposing corners to attach the panels inside the fixture. This allows some space behind the panels for air flow.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
