Big_Katuna
Dec 19, 2013Explorer II
Current increase should be linear to the voltage increase.
The voltage drop across the diode does increase a little with current, creating more loss, but not much. I am in the middle of changing over to LED's and will measure the actual draw with the charger off (12.5VDC) and with it on (13.5)and also the actual draw of the bulb. I'm starting to think 48 LED's at 20 mA @ (.96A) is not a whole lot less than the bulb. Nicer light tho and should last a LOT longer.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
