dieseltruckdriv
Jan 02, 2014Explorer II
I tried to post a summary of an LED test I did, but can't get it to format so it makes sense.
The result was the heat never got over 200 degrees at 14.4 volts. I tested them to 17 volts.
At 200 degrees, you can touch them, but you can not touch an incandescent when it is on.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
