JimBollman
Jan 03, 2014Explorer
I solved the mood lighting mode by mounting a pair of these. They can be mounted with or without the metal hood. I mounted one by the sink with the hood so it could double as a less intense light to use before bed or in the early morning. The second one I mounted back under a wall cabinet and left the reflector off so the whole fixture glows and bounces off the bottom of the cabinet. They worked well for their intended purpose since my wife and I both read eBooks that don't require any light and they draw so little power you can even leave one or more on when your out for the evening so you don't come back to a dark camper.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,409 PostsLatest Activity: May 28, 2026
