EsoxLucius wrote:
The TS-45-MPPT can accommodate 800 watts NOCT. So three 250 watt panels is possible.
http://www.amsolar.com/home/amr/page_164
Yes, however my single panel is putting out over 16amps, so 3 would put me over the allowable rating of 36amps Isc per the tristar manual. Current rating of the controller must be 125% at or greater than solar arrays short circuit current output (Isc).
I also plugged the panel specs into morningstars string calculator and both in series and parallel with 3 modules it exceeds max solar input.
