AlbertaNewbie wrote:
EsoxLucius wrote:
The TS-45-MPPT can accommodate 800 watts NOCT. So three 250 watt panels is possible.
http://www.amsolar.com/home/amr/page_164
Yes, however my single panel is putting out over 16amps, so 3 would put me over the allowable rating of 36amps Isc per the tristar manual. Current rating of the controller must be 125% at or greater than solar arrays short circuit current output (Isc).
I also plugged the panel specs into morningstars string calculator and both in series and parallel with 3 modules it exceeds max solar input.
Put the added panels in series and your Isc does not increase.
Four panels would need to be series/parallel and power to the battery would be clipped at 45 amps. MS MPPT is designed to operate all day at 45amp rating. The string calculator is a bit conservative with wattage. Primary issue to avoid is max Voc.
Morningstar MPPT Controller's Maximum Input Power RatingI can't imagine you would need more than two panels so mostly this is just theory talk.
