Heynow999's avatar
Heynow999
My Tesla powered Toy Hauler
I have built maybe a dozen solar, battery powered trailers over the past 10 years. My plan is to make this the most powerful and advanced one I have built.
I started with a new to me 2010 Heartland Road Warrior. It is a 305 RW toy hauler. It has a 5500 watt Cummins Onan gas generator. I will be installing solar panels and a lithium battery salvaged from a Tesla.
The battery is one module from a Tesla, which has been modified to make it 48 volts. Normally a module is 24 volts but there is a guy in Texas who has figured out how to cut the pack in half and reconfigure it to 48V.
  • Naio,
    Both Outback and Magnum make similar hybrid inverter chargers. They are quite wonderful to use. The Victron is a great piece of kit, too.
  • Naio's avatar
    Naio
    Explorer II
    Glue will help, as will the strap.
    Hey, you might want to post a link to your thread in the Tech forum here. That's where the people you want hang out. But we will ALL be asking you how we can get batteries like yours ;)
  • Naio wrote:
    Your battery 'pen' looks great. I do have one concern. It looks like you have screwed the crosspieces into the cut edge of the plywood. That part of plywood will not hold screws -- they will come out. With the weight of the battery and the movement of the toyhauler, they will come out SOON after you get on the road. I can help you redesign it, if you need.
    Thanks for the advice. I will keep an eye on it. It is screwed and glued. I put the screws in at a slight angle so they go through several layers of the plywood. Maybe I'll run some metal plumbing strap over the vertical pieces
  • About the battery. I actually dont know exactly how many cells are in it, but it is 17 kw. In all the other trailers I have done I used lead acid golf cart batteries. They weigh about 65lbs each. The Tesla battery is equal to about 9 of those batteries. The Tesla battery weights 55lbs. So the Tesla battery is equal to about 585 lbs of lead acid batteries. It should last several times longer than lead acid.
    I have a BMS system that will stop the battery from over-charging so fire should not be a problem. I can also see on the battery pack that each cell has a tiny wire going to it from the buss bar that I believe acts as a fuse for each individual cell. To be safe, I'll put a smoke detector in the compartment. I do intend to use the RV for vacations. The risk of fire I believe is when the batteries are being charged so I will make sure they are not charging at night
  • Naio's avatar
    Naio
    Explorer II
    Wow, that is the mother of all inverters!
    I am thrilled to hear that you got this used Tesla battery. I know there will be a lot of us here wondering: Can we get them? Does your guy sell to the public (or to your forum buddies? :B)
  • The inverter is a Victron Quattro 5000 watt inverter/charger. This inverter has the ability to pass through power from a generator, and produce power from the batteries at the same time. It has 2 inputs for AC power that can transfer 100 amps each, plus 36 amps from the battery, for a massive 236 amps of power! I will be putting the generator into one input, and just one leg of the 50 power cord into the other input
    I am also installing a 100 amp breaker panel. I will feed the main panel in the trailer through that panel, as well as put several more 20 amp plugs throughout the trailer. The reason for this is I am in the film business and I intend to rent it as a hair and make-up trailer so I need plugs for steamers and hair dryers
    mounting the inverter
    mounting the battery
    I built a frame out of 3/4 plywood. I wanted to hold it firmly, but not completely enclose it so it can dissipate heat.
    I propped up the battery about 1/4 inch, then I took several sandwich bags and positioned them around the battery, underneath, above and front and back. I filled the bags with spray foam. The idea is that the battery will rest on the foam, which I hope will also act as a shock absorber as it bounces down the highway.
    This is a work in progress. This is how far I have gotten
  • Yes, keep us posted. And try not to burn your TH to the ground keeping that battery pack cool!
  • Very interesting. Keep us updated on your progress.
  • Fantastic!
    It's interesting that Panasonic (in partnership with Tesla) builds the packs using so many tiny cells... you'd think so many points of failure would be a weakness. I guess their QC must be really high when building these packs.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,397 PostsLatest Activity: Jan 08, 2023
