Ivylog
Jan 30, 2016Explorer III
I sometimes put grey water into my black tank when boondocking. They are on the same level and the two valves are close together but that leaves about a quart of stuff between the valves. By using a $6 end cap with a hose bib and a $5 hose valve I can drain the quart of stuff into the sewer hose before taking the end cap off.
Dennis, if your valves are like mine it's nearly impossible to get the old valve out as everything is that ridged. I had to cut a 1/2" section out of the smaller grey pipe and put it back together with a rubber hose.
Sometimes a hose goes on it instead.:W
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
