rhagfo
Jan 30, 2016Explorer III
Executive wrote:
It takes maybe 15 minutes if you're not mechanically inclined, less if you are, to change out the valve...:S....and that will be a permanent fix.....:)...save your money....Dennis
Well maybe on your unit!
My unit the Grey and Black thank face each other and the valves are right at the tank, with a Y between them. Tried once to loosen and move the tanks just a bit, no luck. The twist on is a good solution for now.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
