John_Joey
Jan 30, 2016Explorer
If you do go this route something to be careful is using a washing machine. Not all washers send waste water into a tank. Some send it straight down the waste line and out. If you have a valve at the end which is shut, then you'll overflow at the washer pipe.
Yes, some valves are very expensive and hard to swap out. Thetford is one of them and may even be glued on.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
