3oaks
Jan 30, 2016Explorer
Executive wrote:Not necessarily true. Time it takes to replace the valve depends a lot on it's location, how rigidly it is lock into place by other drain lines, etc. and whether or not the trailer has an enclosed underbelly. :S
It takes maybe 15 minutes if you're not mechanically inclined, less if you are, to change out the valve...:S....and that will be a permanent fix.....:)...save your money....Dennis
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
