profdant139's avatar
profdant139
Explorer II
Dec 29, 2015
Need a light DIY snowplow for boondocking -- ideas?
So this is one of those "be careful what you wish for" moments. We solved the problem of freezing water lines with a primitive hot water recirculation hose. Now, there is no reason to avoid snow boondocking ("snowdocking?") -- we like snow-shoeing in remote areas. And there are forest roads in the Eastern Sierra that are not gated during the winter, unlike the Western Sierra.
There are two problems, of course -- getting in and getting out of boondocking campsites in snow country. (Let's assume that we will carefully monitor the weather and will not get trapped by a huge snowfall -- yes, that is a risk, but it can be mitigated by the exercise of caution.)
I have seen big heavy expensive plow attachments, but this is something that I want to carry in the bed of my truck for possible use, once in a while. I don't mind something that is "too small" for the job -- I don't need to clear an eight foot roadway all at once. I am envisioning something about three or four feet long that attaches to my hitch receiver, in the back of the truck. Putting the truck in reverse, I would carefully plow just enough of the roadway to get to the campsite, probably within a hundred yards of a paved and plowed road.
That is my goal -- but before I try to invent this device, I am hoping that someone else has already done so!
I look forward to your suggestions and comments. (And no, staying home and watching TV until the snow melts is not a good option, unless I have no other choice. ;) )
  • Gdetrailer wrote:
    Or if you don't mind spending the money, that one is available for $550 and simply straps onto the front of your vehicle..
    HERE
    A strap on? I wouldn't trust it. :W
  • I would not attempt a trip into the eastern Sierra's with only a frame mounted plow - unless I was ready to stay until the spring flowers pop up.
    How about making a plywood "V" plow..
    Like this..
    HERE
  • You should have bought a Chevy. :-) One of the factory options listed for mine was a snowplow. I didn't get one.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,399 PostsLatest Activity: Jan 20, 2026
