TNGW1500SE
Feb 13, 2017Explorer
I see you only have 120 volts to the breaker. Most panels you'll find in stores are set up 240 volts.
If you want a 30 amp main and can't find a panel, just use a "Main Lug" panel (they're smaller) and don't feed the lugs. Feed the panel using a 30 amp breaker using one of the panels breaker slots and mark it as "main". Jump the lugs together so both bars have 120 volts.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
