azrving
Jul 27, 2016Explorer
When I replaced my attwood I believe it came with a new switch panel. It has 2 rocker switches. Propane or 120. If you just have propane it will be the same style plate with one switch. My rig has a dedicated breaker for the WH that runs over to a wall switch before going to the water heater. So the 120 volt wall switch has to be on then the small rocker switch would tell the control board to run on electric. WH also has 12 volts going to it. Rocker switch turns it on and off. Some people like to be able to use electric when they are not paying for electric and save propane.
If I recall there is a block of wood maybe 3/4 thick under mine that may support it. I'd have to look at it again but someone else may be more familiar. It's probably mentioned in the install instructions.
I paid $350 for mine on ebay with 120 volt option too.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
