BarneyS
Jul 28, 2016Nomad
We have always had a Dometic water heater. As far as I know they do not sell them with adjustable thermostats. Looks like you are able to purchase one in aftermarket. The procedure is to carefully turn on hot water and then adjust cold water and hot to desired temp.
The reason I say carefully is because that water comes out HOT - regardless of what the thermostat is set for.
The thermostats are just small button like affairs that attach to the outside of the tank.
Barney
Barney
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
