Old-Biscuit
Jul 28, 2016Explorer III
Atwood has an 'adjustable' aftermarket optional t-stat that replaces the normal temp t-stat. (110*F---150*F VS the fixed 140*F)
The 10 gallon is just slightly larger then 6 gallon
6 gallon.........16" W x 12.5" H x 18" D
10 gallon........16" W x 15.5" H x 21" D
A 'motor assist' option is a aluminum tube welded to tank-----coolant lines from/to engine allows water in tank to be heated while driving.
Atwood Models----see pg. 4 of brochure
LINK
LINK
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
