Str8ball1
Jul 23, 2019Explorer
riven1950 wrote:
Don't have one or any mounting suggestions but thought I would mention a setup I saw in the Keys last winter. This may be common or not. My neighbor had his tv mount attached inside of the storage compartment so that when retracted it was inside the compartment, not attached to the outside wall at all. I believe the tv stayed attached. Downside would be eating up your storage area and of course you would need a storage area where you want the tv. Just a thought. I would not do it because our TT has limited storage, plus we don't need / want an outside tv, but most 5th's and toyhaulers have more storage compartments.
I am not interested in a storage compartment option. Too low and not enough storage as is ...need to have it under awning to block the sun.
I'm not talking about a sealant. I realize it needs to be sealed.
What I have seen is a something that is gray looks a little like play dough between the mount and the fiberglass.
Thanks for your response though.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
