- RobertRyanExplorer
JG wrote:
WOW THAT IS COOL!
Shot from inside of the rear
- JGExplorerWOW THAT IS COOL!
- RobertRyanExplorerWe have a small company in Australia that builds fibreglass fifth wheelers it's models go from 23 ft to 29 ft
This is a 23 foot model that I saw two days ago at a Sydney caravan show
- JGExplorer
Bumpyroad wrote:
JG wrote:
When we looked at RV's we looked a class A, B & C & Trailers. We were worried about spending money & having poor quality & problems. So we accidentally found Fiberglass Trailers. They are ordered directly from the factory. The build quality is very good & they hold there value. Canada has several Fiberglass & regular Trailers that you can order from the factory. Taylor Coach for example. We ended up for us it is just 2 retired people and a dog the Casita Fiberglass Trailer. It tows very easy. Weight is 2800 pounds. Look at Oliver, Scamp, Big Foot ( They have a fiberglass 5th wheel. ) and others. Good luck
when I was looking, I went to the Casita factory in TX and rather liked their bathroom layout compared to the scamp. to get a full height coat closet you needed to get the roof AC unit, not the lower one that was located at the bottom of the closet area. had a small table on the side with two swivel chairs and you could leave the dinette made up as a bed full time if desired.
bumpy
We love ours. We park our in our back yard because of our HOA. I put on a front trailer hitch. Works great. What did you end up getting? We did not look at the Scamp because of the driving distance for us. I think they all are nice now days. - penguin149ExplorerWet bath is a no-go for me.....even more so for the wife! MY HTT is fiberglass sided and MUCH easier to keep clean, wax, etc.
- BumpyroadExplorer
bumpy - JGExplorerWhen we looked at RV's we looked a class A, B & C & Trailers. We were worried about spending money & having poor quality & problems. So we accidentally found Fiberglass Trailers. They are ordered directly from the factory. The build quality is very good & they hold there value. Canada has several Fiberglass & regular Trailers that you can order from the factory. Taylor Coach for example. We ended up for us it is just 2 retired people and a dog the Casita Fiberglass Trailer. It tows very easy. Weight is 2800 pounds. Look at Oliver, Scamp, Big Foot ( They have a fiberglass 5th wheel. ) and others. Good luck
- WNYBobExplorerI have a Dutchman type camper with "fiberglass" sides. Most are built with a skin (and I mean thin) layer of fiberglass glued and pressed on to a luan type backer (which is wood). If moisture (humidity or water) gets to the wood the fiberglass pops off in what they call delamination. If you get delamination you have lost thousands in value of your RV.
A few use ANSDEL backer for the fiberglass, which is water resistant. - LwiddisNavigatorI didn’t consider a Scamp because they don’t have slides.
- rbpruExplorer IIWhat you are referring to is typically referred to as an egg or shell camper.
We looked hard at these but no slide and too small for two adults and a 70 lb. Dog.
Generally lighter in weight with fewer seams they get good reviews from their owners. But they were too small and tight for us.
We own an old school stick and tin (aluminum) 2010 model with over 40,000 miles on it.
Basically you buy the floor plan you want. It is your biggest concern.
Good luck
