Str8ball1
Jul 23, 2019Explorer
Lantley wrote:Str8ball1 wrote:Lantley wrote:
Try This. No Drilling Required
***Link Removed***
Yeah I have seen those. Expensive and dont trust a suction cup much.
Thanks though.
I agree they are expensive but they work, You can trust them to hold.
I don't have one but I have seen them personally. They are a worthwhile option if you can stomach the price.
Once you consider your alternatives, there is no other option quite as simple and to the point as the suction cup. No drilling, no penetrations.
No marks, no alterations
Otherwise you need to construct some sort of cabinet or permanently mount some sort of bracket to your exterior.
The suction cup eliminates the need to do anything permanent.
I also worry about it separating the fiberglass. Delamination? Just can't imagine applying the suction required in that area without that concern. I probably worry too much.
I dont mind having a mount permanently up if it is strong. I have already purchased one I can move the TV from mount to mount
Now I just need to install on the camper.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
