Str8ball1
Jul 25, 2019Explorer
Lantley wrote:
Another option I have seen is to just put TV on a folding table.
I have also seen TV suspended from and awning.
As Barney mentioned above you can through bolt it easy enough but I have never seen an RV with a TV bracket permanently mounted to the side.
Either you and I are talking about different things or something else because about every new travel trailer has an outside tv mount under the awning.
I just dont know what has been used between the mount and the fiberglas to keep it from contacting the fiberglass.
How would they suspend from the awning? In the sunlight I cant imagine that would be visible if it's on the end.
I've considered the folding table but at a tailgate that would be susceptible to being knocked over. The sun again would be an issue without being high enough.
Thanks for the ideas though.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
