Str8ball1
Jul 26, 2019Explorer
DrewE wrote:
Why would they care to keep the mount from contacting the fiberglass? Window frames contact the fiberglass. Awning support arm brackets contact the fiberglass. Door hold-open gizmos are mounted to the fiberglass. I can't think of any reason why a TV mount would be any different. I still suspect what you're seeing is just a sealant or gasket of some sort to keep water out.
I dont know but I assume it's the possible weight shifts the mount may have on the fiberglass. I assume awnings etc have something specifically made to hold it and support it behind the fiberglass.
What I saw in the video is not a sealant that I have seen used any time before.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
