JiminDenver
Nov 17, 2015Explorer II
Another way of looking at it is yes the solar is small for the four 6v's but compared to the needs it isn't. It should easily cover the need depending on the conditions. Worse case is if the solar can't keep up due to bad conditions for long enough, you would have to fund a alternate means of charging be it running a generator on a extended trip or plugging in once you are back home if the batteries don't get too low before then.
Even with a large bank and a better than 1 to 1 ratio watts to Ah, there are going to be times when it's bad enough for long enough that I'll have to run a generator.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
