Chris_Bryant
Jul 18, 2019Explorer II
out_west wrote:Chris Bryant wrote:Old-Biscuit wrote:
My current wiring setup on my analog is:
1. Red wire +7.5 volts ------NOT USED (Cap/tape off)
2. Yellow Wire to Cool -----to A/C ("Y")
3. White Wire to Furnace ---to Furnace ("W")
4. Blue Wire to Hi Fan ---High Fan ("G")
5. Orange Wire to Low Fan ---Low Fan (Cap/Tape off)
6. Black Wire to Ground ----TO 'RC/RH' jumpered terminal
This, with the exception that you need to connect both high and low fan- the Dometic analog system switches grounds to energize the relays (not +12 vac), and the fan is two relays, low fan relay energizes the blower, hi fan relay switches between hi and low, so both must be grounded.
Chris, just trying to get clarification on this since I have to purchase another digital thermostat to try now that I'm finally getting somewhere with using the ground instead of the +7.5 red wire.
1. So if I jumper both Low and High wires together, the fan will work in high mode?
Yes
2. If I were just to connect to the High wire, the fan will not blow without also jumpering to the Low)?
Correct
3. What if I were just to connect to the Low, the fan would work in Low?
Yes- the low turns the fan on, the high just switches between high and low. They did this so there is no way both high and low can be energized at the same time
4. I wasn't planning too initially, but can I run a switch like others have done to still get Low and High speed fan control?
Yes- it will be a simple spst switch just connecting the high and low together.
Thanks for any clarification....
No problem :)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
