out_west1
Jul 18, 2019Explorer
I have one more question if anybody might know the answer. I tried the Coleman Airxcel 8330-3362 digital thermostat (before knowing about the ground) which is for RV's (it is not a home thermostat). The Coleman does not run off batteries (like the home ones), and connects using 6 wires just like my Analog does. The plus about the Coleman is it already has a fan low and high setting.
Do you guys know if the Coleman would work in my setup if I swapped the red hot wire, and ground wire positions? Or is that going to piss off the thermostat itself?
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
