out_west1's avatar
out_west1
Need help, upgrading Dometic Analog Thermostat to Digital
I've tried upgrading my Dometic Analog thermostat model number 3107610-002 to a Digital thermostat with no luck. My AC model number is a Dometic Duo-Therm 59516.331.
I've tried three different Digital Thermostats listed below with no luck (and wiring per instructions found in many different references online).
Tried:
1. Honeywell RTH2300B
2. LUX DMH110
3. Coleman Airxcel 8330-3362
My current wiring setup on my analog is:
1. Red wire +7.5 volts
2. Yellow Wire to Cool
3. White Wire to Furnace
4. Blue Wire to Hi Fan
5. Orange Wire to Low Fan
6. Black Wire to Ground
In wiring the two different "Home Style" thermostats I've wired my Red +7.5 volts to the positive red wire RC/RH which is jumpered on thermostat, Yellow wire to AC wire, White wire to furnace, and I wired just my Hi fan wire and capped off the Low wire and the ground wire (since not being used since powered by battery from thermostat). Nothing worked at all.
So I tried the Coleman Digital thermostat which was almost an exact wire for wire match (minus a couple different colors), but I matched my wires to the matching wire uses on the thermostat, and again nothing would turn on at all.
Has anybody dealt with this? Does anybody have recommendations? I sent off an email to Dometic wondering if I need some sort of different control board, but it doesn't sound like I should have to go to that extreme to upgrade to a Digital thermostat when so many other RV users do it all the time.
Any help appreciated........
    1. Red wire +7.5 volts ------NOT USED (Cap/tape off)
    2. Yellow Wire to Cool -----to A/C ("Y")
    3. White Wire to Furnace ---to Furnace ("W")
    4. Blue Wire to Hi Fan ---High Fan ("G")
    5. Orange Wire to Low Fan ---Low Fan (Cap/Tape off)
    6. Black Wire to Ground ----TO 'RC/RH' jumpered terminal
    This, with the exception that you need to connect both high and low fan- the Dometic analog system switches grounds to energize the relays (not +12 vac), and the fan is two relays, low fan relay energizes the blower, hi fan relay switches between hi and low, so both must be grounded.
  • My current wiring setup on my analog is:
  • Flute Man wrote:
    Contacting Dometic is the proper way to go. They can tell you which digital thermostat is compatible with their system .....if any.
    X2 Additional equipment may also be required.
  • Contacting Dometic is the proper way to go. They can tell you which digital thermostat is compatible with their system .....if any.
    Jerry Parr
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,368 PostsLatest Activity: May 03, 2025
