Old-Biscuit
Feb 10, 2016Explorer III
rwsellers wrote:
I have a 91 Fleetwood Prowler 34F. The thermostat needs to be replaced. Local service guy says it's a Coleman Robershaw model. The front plate reads Remote Control Coleman. The furnace is a Coleman as well.
The thermostat has 7 wires in the back.
Any suggestions where I can find one in stock or a workable replacement?
Thanks,
Rog
A Honeywell Digital T-stat (Model Honeywell RTH3100C) should be a good replacement.
What are the color of wires on old t-stat?
What terminal does each color wire go to on old t-stat? (Mark them/label them/ID them PRIOR to removing from old t-stat!!!!)
Do you have heat pump?
What model is Furnace?
What model is A/C Unit?
Answer those questions and a wiring diagram for swapping out t-stat can be posted.
Honeywell Manual
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,413 PostsLatest Activity: Jul 22, 2026
