DiskDoctr
Jun 24, 2014Explorer
Need suggestions for rebuilding large cargo door
Ok, I've decided to rebuild my very large and expensive to ship cargo door.
Fairly confident I can remove inner and outer layer to replace just the internal part of the laminate.
I'm looking for (reasonably priced) substitutes for the wood.
Water resistant, light weight, rigid, able to support using the plates on the gas shock arms.
I considered rigid foam, but at only about 3/4-1" thick, may have to build wooden frame to do that.
If I could find a reasonable source/price for birch-foam-birch (think luan on each side), I'd consider it.
I plan a MUCH better seal at the edges than oem, which seems to be the source of the problem.
Budget without labor about $100-200.
Ideas?
Ideas?
