duderockwell's avatar
duderockwell
need to change a fuel pump
Hello , I have a 1999 Winniebago Adventurer 35ft with v10 6.8l ,im wondering if there is enough room between the inside floor and the fuel tank for me to cut a hole into through the floor so i can get to the pump and change it from inside, and if there is enough where is the prime spot to put a hole? please help im running out of time to get this running, thank you so much for any help?
1 Reply
  • I truly hope somebody comes along and proves me wrong on this one.
    Unfortunately I don't think any of us can tell you where the fuel pump is in relation to the interior of the coach. You might be able to make a guess by looking at the gas cap and then looking under the coach and tracing the fill hose to the tank. From there you have to find a way to visualize the interior so you can go into the coach and see if the area of the floor you imagine it's under is something that might be accessible.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
