time2roll
Mar 08, 2019Nomad
deadticket8 wrote:The linked converter will charge at 14.4 volts for 4 hours before it drops to 13.6 volts. There is also a manual override to go another 4 hours in boost mode.
Thanks for the info, but I do not have an RV. I used to though. Now I have a cargo trailer with a solar setup. I am looking for a good charger that can be plugged into a 2000 watt portable generator when I am parked in the shade. Need something that will top off batteries not stop charging at 12.5 or there abouts.
Not high enough? There is a similar model that goes 14.8 volts to match the Trojan GC2 spec.
http://www.bestconverter.com/9200-148-Modified-Deck-Mount
Not fat enough? Get the 80 amp if you want more power.
That CTECH is fine too at 25 amps will take a bit longer.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
