- TakingThe5thExplorer
hershey wrote:
I found one that has four USB ports, no AC outlets at all. Unfortunately, they are now all filled and I need more. One thing, my wives smartphone won't charge off of them. It has to use its own AC to USB adapter. Everything else seems to work.
I had a similiar problem with a mult-purpose car jump starter/air compressor that also had USB ports and a cigarette lighter socket. The USB ports would not charge my iPhone 5 but a USB adapter that I put in the cigarette lighter socket did work. I discovered that iPhone needs at least a 1 amp output but the USB sockets provided only a half amp.
The good news is that there are wall plates out there with higher outputs. - nineoaks2004ExplorerPretty neat, I am thinking of doing an install in my pup seems everything (almost) uses USB chargers..
- hersheyExplorerI found one that has four USB ports, no AC outlets at all. Unfortunately, they are now all filled and I need more. One thing, my wives smartphone won't charge off of them. It has to use its own AC to USB adapter. Everything else seems to work.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,405 PostsLatest Activity: Apr 21, 2026
dded a new outlet with 2 USB charging ports
