Dutch_12078
May 01, 2016Explorer III
I used exactly the same fan, Joe. To install it, I just did a bit of tin knocking to square up the round opening for a better fit, and used nylon spacers and longer screws to mount it. This was the second coach I made th mod on, and I did use the speed control on the first one, but as ou said, it's not needed, and I didn't use it this time. Because the fan is so quiet, I also added a small red LED through an 1/8" hole I drilled in the front panel next to the switch so we won't forget to turn it off. All in all, a great mod!
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
