Joe_Way
May 02, 2016Explorer
Soundguy, I see in your video that your mod works by reducing the fan speed. That wouldn't have helped me. The original fan moved less air than my replacement fan does at full speed. If the speed of the OE fan (mine, anyway) was reduced enough to make the noise tolerable I suspect it wouldn't move enough air to be effective.
I think the biggest factor is the number of blades--seven for the new fan vs. three for the old. The old motor by itself, without the blade mounted, is pretty quiet. The higher blade number is, to me, worth the work.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
