you can get amish made replacmet heating units, I imagin they are the same idea as the ones you are looking at.
they look very easy to install and are intended for DIY, you would have to watch a couple videos, which you have done.
for myself personaly haveing only ac in a rv reduces the vaule as your stuck to camping with hookups so you cut a lot of your market out. if you never looking to sell it and you only camp with power and don't drive to far from home to get there, or run a genny all the time then your fine
"if you never looking to sell it and you only camp with power and don't drive to far from home to get there, or run a genny all the time then your fine" Apparently it will run on a 1000w inverter.
- StirCrazyApr 08, 2024Moderator
yup, and if your not worried about resale thengo for it, I would get a bigger inverter say a 1500 to be safe. and make sure your batteries and altanator are yup to snuff to power it while friving and your golden
