GordonThree
Apr 10, 2014Explorer
Voyager35L wrote:
I know I saw directions how to wire a computer fan to the inside light and bypass the switch so that it is always on in my refrigerator. Does anyone know where the directions are? I just don't want to cut into the wires.
If you don't want to cut wires, you can use something called a vampire tap aka quick-splice. You open it, slide it over the wire you want to use, close it a little, slide in your new wire and then squeeze it shut.
You'll need to find the battery-voltage wires that power the circuit board in the fridge, they should be always-on. I'm sure someone will have more details about where those wires are, as I have not done this mod yet. You don't want to mess with the AC voltage wires that go to the shore-power heating element.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,398 PostsLatest Activity: Dec 28, 2025
