RvBill3
Apr 15, 2014Explorer
On the refrigerator light, one side will be powered whenever the refrig is on. Connect to that terminal. (The other terminal on the light will be powered only when the door is open and the light is on. Check by holding light switch in and see if the terminal still has power.) The other wire for the fan needs ground. Clip it to one of the cooling fins. I bought a commercially available computer fan setup (eBay) and that was how it said to wire it. Works fine. On whenever the refrigerator power is on.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,398 PostsLatest Activity: Oct 07, 2016
