KTMMike
Apr 25, 2024Explorer
Oops...accidentally submitted post before I was done!
Options:
Spring over conversion
Possible taller than I'd prefer. But given that my spring hangers are made to be adjustable, could I do spring over, then move spring eyes and equalizer to upper hole. End result should be 3 to 4" of lift. But, as is, with equalizer in lower hole it can actually contact hanger along angled side as it gets wider. Upper hole will guarantee that will happen. Could I cut the boot hanger down to a more typical rectangular hanger to increase clearance?
Upgrade springs from 5200 lb to 6000 lb? How much higher would the heavier springs raise the trailer.?
Other options..?
Thanks Mike
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,419 PostsLatest Activity: Sep 14, 2026
