74vette
May 09, 2013Explorer
Cab to trailer clearance
I have a CC 6 1/2' box Silverado 2500HD. The pin box on a fifth wheel I am looking at is 12 inches in front of the trailer front cap. Is there a formula to see if I need a slider hitch.
Traveler II wrote:.07PSDCREW wrote:
I don't know if you have a hitch already, or can borrow one if you already have the rails. I Meashured my trailers width and divided it in half. Then Meashure from the back window to the center of where the hitch would be in tow mode. If it is a lot less than the width of your trailer divided in half then I would get a slider.
Example. My trailer is 97" wide in front. Half that is 48.5". The meashurement between my aluminum back rack and the center of my hitch in fwd position is 36.5" So I bought a slider. I also opted for the Reese round tube as it had 12" of travel as opposed to the square tube 10"
For a rough estimate, you can judge just about where the center of your rear axle is under the bed of your truck, then go 1" inch or so in front of center towards the cab for your reference point. Most hitches run centered over the axle or just in front of it.
Good luck.
How would you calculate this is you have and extended pin?
Good luck.
