DW has never liked the oven in our '96 adventurer so it's been used primarily as chip storage. She wants it removed and build in a better cabinet for storage. The plan is to take out the oven and coun...
Just FYI. check what kind of wiring is running to the microwave if it is in a slide. Ours has household wiring run through the regular walls but the slides have a flexible wiring almost like an extension cord. I tried to put in a convection combo and it would not hold the amperage. Just a thought. If MW is in a stationary wall you should be fine.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
