hikerboy1's avatar
hikerboy1
PD4655 converter question
I am going to replace my main board assembly of my WFCO 8955 converter with a Progressive Dynamics PD4655 assembly. I know that the PD unit will come with a new 12 volt fuse block assembly, but is it really necessary to swap it with the existing WFCO fuse block? I see the PD fuse board comes with a LED button for manually overriding the output voltage, but if the converter is working correctly, I'm guessing I wouldn't need to override it anyway. I had a PD unit in our last trailer and I never overrode it's circuitry in the 10 years we owned it, it sensed what it needed to do and did it well. Certainly better than the WFCO unit in our new trailer.
Also not sure if we really need the 55 amp model - thinking that the 45 amp model would work just fine, and wouldn't tax the Honda EU2000i generator as much. We have 2 group 24's on the trailer.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
