Hammerboy's avatar
Hammerboy
Permanent sewer hose connection
This has been on my list of mods for a while and I finally got around to installing a semi permanent sewer hose system. I purchased the hose and storage box on E bay this past winter from an RV parts supplier for about the price of just what the hose sells for currently so I couldn't pass it up. This system allows me to leave the hose permanently attached (can be taken off) and has a clear view on the business end along with a open/close valve. This may be one of the best mods I did this year hopefully. I can't find the link to the original page that showed the install instructions but it was on the drainmaster website.
Dan
[img][/img]
[img][/img]
  • Dick_B wrote:
    Keep valves open or closed? That is the question. Certainly the black valve should be closed but I sometimes cheat and leave the shower valve open until I need the water flow to clean out the hose.
    You would still use the valves as you normally would. I guess the main advantage is you don't have to connect and disconnect your sewer hose. It's pretty much self contained. Tonight when I have more time I will try to figure out how to post pictures and post a link to the manufactures website
    Dan
  • Keep valves open or closed? That is the question. Certainly the black valve should be closed but I sometimes cheat and leave the shower valve open until I need the water flow to clean out the hose.
  • Apparently the uploads didn't work, I'll have to figure it out later.
    Dan
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,385 PostsLatest Activity: Aug 08, 2025
