ktmrfs
Feb 22, 2018Explorer III
SoundGuy wrote:Matt_Colie wrote:
Not only is Gordon right about "Where's the fuse?"...
Why would the OP need a "fuse" when no doubt that positive battery cable running back to the trailer first goes directly to a resettable circuit breaker, most likely mounted on the trailer's A-frame. That's the "fuse". I'd agree though, regardless of the colour of wire used I'd mark each as POS and NEG for ease of identification. :)
well, on the fuse. First, it's highly likely that the trailer fuse
1) is an automatic reset, which means it will open, close, open close....get the picture for a short
2) highly likely it is not rated to interupt the current that the battery bank can deliver and can end up not being a fuse but a welded shut contact
3) won't protect if the battery cable shorts BEFORE the trailer fuse.
On my trailers I have a appropriate sized and rated fuse at or very near the battery bank.
And second, I replace the typical factory trailer breaker with one that is NOT automatic reset, but manual reset.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
