MrWizard
May 17, 2017Moderator
four panels parallel
shade on one panel, only hurts that panel
the other panels will continue to have output
do you use your awning ?
i will normally park awning side to the sun, if I have the choice
so put the 4th panel on that side of the A/C unit, it will be in the sun more times than in the shade
I know..depends on where the Batwing lays down !
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
