cfcubed
Jun 30, 2017Explorer
UPDATE 6/17 (from the Instructable): Having re-tested this design with generator under moderate -> heavy load, not in econo mode, for a sustained period I felt exhaust side temps were too high. Small sections of plastic bread keeper on exhaust side got > 90c. Ordered 240CFM replacement fans & will be using a $18 steel mailbox on exhaust side, with larger/taller outlet side hole, to see how that works/helps. My prior tests were shorter / lighter load / econo mode ones.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,415 PostsLatest Activity: Aug 04, 2026
