cfcubed
Jul 22, 2017Explorer
rickhise wrote:
Don't kid your self put a thermostat that reads the temp
sometime, you will quickly learn regardless how many
times u change the oil. The heat has this motor doomed
Of course this is a primary concern, one that "proper" testing & temp readings should address, at least to the satisfaction of builders/users of boxes. Though it'll be tricky to get internal temp measures (engine,gen,inverter) I'm going to try.
As always in DIY, you research/assess info & reports and decide cost/benefit for yourself.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
