I think Im going with the 1100 watt unit from krieger..
That invertor should be sufficient for my needs.
Turn off A/c breaker, water heater breaker, micro wave breaker, and I believe refridge breaker.
I hope the breakers are all seperate...lol This will just insure no one trys to run these High draw appliances.
The invertor is 1100 watts so the manual stats 9 amps or so.
I wonder if there will be a voltage drop going from invertor yo long RV cord. I plan on running an 10 gauge carflex whip from a junction box near the invertor to an outside TT outlet.
Then make a pigtail from juction box to plug into the invertor. I will put invertor near the batts in the front compartment using upgraded #2 wire I have.
I also wonder that this invertor is 90% eff what are also the loses going into the convertor @ 120 and converting to 12v.
Since now that im plugging into the invertor the 12 stuff runs off the convertor and not off the batts directly I would assume?
